Message 31 of 35
Re: Full Fibre 900 WiFi speeds
You can keep the SH2 there but then you need to change a bunch of settings... I did it years ago and its a pain... so i put my 3rd party one in direct, and set it to PPPoE and so on... perfect
Be a first rate version of yourself, not a second rate version of someone else
Message 32 of 35
Older devices are getting 450 to 500 e.g with a 8260 Intel wifi card in a laptop
Message 33 of 35
I just plugged laptop direct into router and got 250!!!  then I set up a direct  connection to the white box, speed spiked at 980 for about 2 seconds then gradually dropped down to 250?  is there something wrong with my connection or is it the "known but unpublished issue" with the speed test sites and the service?
Message 34 of 35
I haven’t tried WiFi via the SH2 but if you install a carefully distributed Wi-fi network in your home, hardwired and carefully placed to distribute devices without channel cross over to reduce interference and multiple transmissions it’s possible to get decent speeds.
Depending on your device being 2x2, 3x3 or 4x4
This is 5 runs from an iPhone 11.
I’ve seen just over 600Mbps on an iPad Pro.
The APs are WiFi 5 (AC)
BT 900
Wired maxes out as you’d expect
Message 35 of 35
Openreach been today apparently my speeds won’t show on test sites as it’s brand new system all the software through the system etc has to be updated or evolve?
