m0ssim0
Message 1 of 1
Full Fibre & Triband mesh or WiFi 6 mesh
Hi, I'm due to move on to Full Fibre 900 soon and will likely have to replace the Smart Hub 2 with a mesh WiFi system which I believe can be plugged straight into the ONT connecting via PPPoE. I'm after a system which is capable of providing Wifi speeds Full Fibre 900 provides and to achieve this I understand I need one with good 'backhaul'. I was looking at either of the ZenWifi units, the Triband version or the WiFi 6 one or the Triband Velop AC6600. Is anyone currently using any of these units with FTTP, any problems? Can anyone recommend any other meshhmesh systems they are using which will take full advantage of the speed via WiFi? Thanks
