TTW
Message 1 of 7
Google Wi-fi into home hub 6
Hi, I hope someone can help!  I’ve had my google Wi-fi plugged into my my home hub 6 (fttp connection) but the home hub produces an IP address and so does the google Wi-fi so this is creating an unstable Wi-fi connection (as two competing IP addresses). How do i rectify this? Can I do away with the home hub and essentially connect the google Wi-fi directly via Ethernet cable to the fibre connection? Or do I need to by a separate bridge only modem to replace the home hub first?? Thanks ... !
6 REPLIES 6
Message 2 of 7
Re: Google Wi-fi into home hub 6
Google wifi has its own router so you don't need the hub. Connect it directly to the ONT (which is a modem).
TTW
Message 3 of 7
Thank you! Now I’ve connected the google Wi-fi to the ONT it’s asking me to select:
DHCP
Static IP
PPPoE
which option is it? I tried PPPoE
and then called bt to get username and password which is bthomehub@btbroadband.com and password is BT .. but this gives an error message .. is this the right option? Or do I select DHCP? Thanks again .. 😉
TTW
Message 4 of 7
  • Hi, I’ve connected my google Wi-fi directly to the ONT but the ONT also produces an IP address? Which is strange as I thought the ONT was a modem .. how do I remove this IP address so it doesn’t interfere with the google Wi-fi one? Should it still be in PPPoE setting or something else?
Any advice greatly appreciated! Thx
Message 5 of 7
PPPoE and the username and password you have been given are the correct options.
TTW
Message 6 of 7
Thanks. I’ve put them in but ONT still generating an IP address. Anyway of preventing this? Thanks again !
Message 7 of 7
The ONT can't generate an IP address, it's a modem. The Google WiFi will be generating the addresses
