kwaker5
Message 1 of 9
Google classroom and BT parental controls problem
My children are at home using Google classroom.  We can't access the files that have been uploaded by the teachers unless I switch off BT parental controls.  This is really annoying and seems unnecessary.  Can anyone help?
8 REPLIES 8
JohnC2
Moderator
Moderator
Message 2 of 9
Re: Google classroom and BT parental controls problem
Hi @kwaker5 check out the Allowing Blocked Websites section on Parental Controls and see if that helps.
cheers
John
kwaker5
Message 3 of 9
Thanks but the URL varies for every piece of work and is completely random so it's not an option.
Keith_Beddoe
Message 4 of 9
I do not use BT Parental controls, however most of them rely purely on the actual web domain, as determined by DNS, so that if the main domain name is the same, then you can make an exception to that, instead of an individual url. Look at the bit just after the http or https.
Try adding https://edu.google.com
The other option would be to temporarily disable it for the period of time that the school work is being completed.
DanielS
Moderator
Moderator
Message 5 of 9
Hi @kwalker, This issue, within Parental Controls, may ha...
Hi @kwalker,
This issue, within Parental Controls, may have been caused by the use of drive.google.com domain ​​​​​​in GSuite.
That link will be blocked for "File Sharing" under out strict filter settings. You can edit your strict settings to remove file sharing.
Let me know how you get on, please.
DanielS
shibes
Message 6 of 9
BT Parent Controls will need to be edited, simply uncheck "File Sharing" under the list of Options, as follows:
Broadband security/BT Parental Controls/Manage/Your parental controls filter/Change/File sharing (uncheck)/Save
kwaker5
Message 7 of 9
Thanks, the on/off thing is what I have resorted to in the past but will try unchecking the file sharing option suggested by 2 other contributors.
kwaker5
Message 8 of 9
Thanks for your help.  Removing (unticking) the File Sharing option from the custom settings in Parental Controls worked.  I have also fed this back to my son's school in case anyone else is having trouble.
talldave
Message 9 of 9
We had a similar problem which was very annoying with the kids doing schoolwork. Thanks for all the threads here which helped solve it. I had to do the following:
Your security at top of screen
Turn these on
Allowed and blocked websites
Insert into the allowed websites: docs.google.com
Save
Hopefully this will work.
