ryant1983
Newbie
Message 1 of 2
Google wifi and smart hub
Hi, I currently have BT fibre and a smart hub. The signal is generally quite poor around the house. I am considering disabling wifi and hooking up a Google wifi mesh network to the smart hub via the ethernet ports as the sole wifi signal. Please could someone tell me if this is a viable solution?
1 REPLY 1
Message 2 of 2
Re: Google wifi and smart hub
As far as I'm aware, Google mesh is a router as well as a mesh wifi system. The home hub doesn't have a modem only mode so unless you want double natting etc you would be better off buying a separate modem as well as the Google mesh and not use the HH at all.
