Message 1 of 15
Google wifi
As I've had enough of my unsmart hub, I am looking at alternatives that work with BT UHD TV.
i was planning on getting a Google wifi setup, but folk seem to have issues with this although Google say if parental controls and be protect  are off it will work. There's not much to be found on this forum on this, has anyone got it working?
or tried a TP Link Archer v900v2 ?
14 REPLIES 14
Message 2 of 15
Re: Google wifi
Have you had the smart hub replaced as faulty? I had one sent to me in March on recontracting and it kept going slow, took ages to start up and was basically awful. The replacement hub so far has been flawless, both with the bttv and particularly the WiFi which is much improved upstairs. Might be worth a try if you haven't had the original replaced.
Distinguished Guru
Distinguished Guru
Message 3 of 15
Re: Google wifi
the connected devices subforum has some discussions that ight be useful eg
https://community.bt.com/t5/Connected-Devices-Other/TP-LINK-Archer-VR900-or-BT-HH6/m-p/1717932/highl...
Expert
Message 4 of 15
Re: Google wifi
I use a TP-Link Archer VR900 but mine is a v1 and I'm still on the factory firmware, only because I had to use this for Vision+ and never bothered to update it when I upgraded to YV. The VR900 is massively more reliable than the 'smart-hub' which caused no end of issues with me.
i have a fairly complex home network with lots of home automation on Wifi (things like Hive, Nest Alarms, alarm system, CCTV, LED lighting) plus a fair bit of home entertainment on LAN (everything from Sony High Def audio system to DVD home cinema and TV's) plus the usual iPads, iPhones PC's and printers ... the VR900 handles them all happily, wifi is acceptable range-wise.
I'd never go back to using a BT hub now. Not worth all the angst.
Expert
Message 5 of 15
Re: Google wifi
My Home Hub 3 in the last 4 or 5 months has been plying up once in a while with wi-fi even though it say all conected and Hub 3 says all fine.
Have found BT customer service to be at times less than helpfull with the mater. Even though I have told thim they only seem to temporary fix the problem at times. I think the Home Hub 3 maybe starting to play up with the wi-fi for never had this problem with wi-fi a year or so ago.
Darren
Message 6 of 15
Re: Google wifi
I have bought the Archer router, which I am planning on turning off the wifi so the BT box connects using ethernet which I am hoping means UHD TV works, than getting the google wifi for, well, wifi.
Or am I missinmg something.
Message 7 of 15
Re: Google wifi
@duffy502 wrote:
I have bought the Archer router, which I am planning on turning off the wifi so the BT box connects using ethernet .
Connecting via Ethernet is not dependant on turning off wifi.
Message 8 of 15
Re: Google wifi
I do not understand that?
If the router is handling the wired network, and google only the wifi, my plan should work, no?
Message 9 of 15
Re: Google wifi
Yes, but you implied that in order to connect to your TV via Ethernet you need to turn off wifi on the Archer. The router can handle both.
Message 10 of 15
Re: Google wifi
Oh I see the confusion sorry.
No I want to replace the rubbish smart hub, get the archer as many good things said about it working great with BT and replace my repeaters with Google Wifi, as its great apparently but does not play well with BT on its own due to multicasting issues.
