Message 11 of 15
Re: Google wifi
All makes sense now. If you don't intend using the Archer for wifi, it might be worth considering a cheaper model as most of the benefit of the more expensive models is in improved wifi speed.
Expert
Message 12 of 15
Re: Google wifi
AIUI, the Google wifi things are only useable in 'mesh' mode when the master google thing is effectively the router. If you use it in Bridge mode, which you have to do if you are connecting it to your router and replacing the routers wifi, then MESH won't work ... that's what I read into the pretty rubbish instructions for the thing.
Message 13 of 15
Re: Google wifi
Just when I thought I was getting somewhere, maybe I'll try the BT mesh offering, the press seem to like them.
I said I would never buy BT hardware again too.
Message 14 of 15
Re: Google wifi
You could always get an Openreach modem rather than the archer and use the Google wifi as your router and wifi.
Scrub that, just seen the reason for the Archer.
Message 15 of 15
Re: Google wifi
That was my original plan, and I have 2 open reach modems, but no it won't work apparently.
