subair37
Message 21 of 36
Re: HH 5 Replacement !!!!!
Which port is ftp connection ?
Distinguished Expert
Message 22 of 36
The ports are 20 and 21
Is the FTP server on your network or on the Internet somewhere?
To say thanks for a helpful answer, please click the white star
subair37
Message 23 of 36
It is on the internet some where as i had lots of issues connecting to my ftp through home hub 3.0 , that is why upgrading to hub 5 , Please some one shed some light on ftp connection using hub 5
previous post says closed ports are 0 to 79 is that mean i am  not able to connect to my ftp using hub 5 ?
Message 24 of 36
Please look at the other thread you posted. Most incoming ports are blocked, unless they are part of an existing transaction, like http, ftp, etc.
Once a session is closed, the port is closed.
Message 25 of 36
If the FTP server is on the internet then you don't need to open any ports. You only need Port Forwarding if the server is on your network. However, your firewall may still be blocking it.
In addition, the FTP server may be wrongly configured as ACTV but you need it to be PASV as you're using NAT.
subair37
Message 26 of 36
hi keith
i did not understand any thing , can you please make it simple , connecting to my ftp using home hub 5 is it possible or not ?
subair37
Message 27 of 36
thanks legitimate , so i can connect , but now i am having problems with my hub 3 that is why i am upgrading to hub 5 thinking i can connect hopefully.....
Message 28 of 36
Are you running any firewall apps on your computer?
subair37
Message 29 of 36
iI got windows fiirewall and AVG internet security as both i have added filezilla as exception
Message 30 of 36
What client are you using to access the FTP server?
