MartinPorter
Message 11 of 36
Re: HH 5 Replacement !!!!!
Well.. got myself a HG612 (unlocked) and as yet - no OpenRG calls! Still have the problem with the speed
right now I have a 70mb come 4pm it will be down 25-30mb and stops at that till 8am the next day...
Someone pointed me in downloading a HG612 Stats logging software which should help getting my point
across to BT support! - would you know what make is the HH5? I was also thinking how long will it be till
someone will unluck this unit?
Barry57
Expert
Message 12 of 36
If you modem has kept connection?
Would that point to something else on the network/exchange  that is slowing speeds at peak times ?
They are good those unlocked modems.Having got used to seeing all the info, I don't know if I would move back to the HH5 even if BT get round to fixing its issues.
MartinPorter
Message 13 of 36
Hi - Which modem are you running with?
Barry57
Expert
Message 14 of 36
Hopfully Both soon 😉
The line has settled back down with the ECI version & is in "Fast" mode which I think is the best ?
Do like the look of the ease of use of the HG612 and would be good to see if there is indeed a difference between the two types of modem on a longer line like mine.
Distinguished Expert
Message 15 of 36
I believe it's a Sagem. Why do you ask?
To say thanks for a helpful answer, please click the white star
MartinPorter
Message 16 of 36
I found some software that will monitor/log the modem.
Message 17 of 36
Was it RouterstatsHub?
MartinPorter
Message 18 of 36
It was...LOL Smiley Happy
subair37
Message 19 of 36
Hi Friends
Bit confused after reading all the above posts, my home hub 3 was giving me a lots of problems in connecting to my filezila ftp, so i ordered a home hub 5 will i get problems with that as well ? When i receive the hub shall i have to connect the open reach modem that white box to home hub 5 , Can some one explain how to get the set up done on home hub 5  please.
MartinPorter
Message 20 of 36
I have just checked on my HH5 ports open are -
80,139,445 & 433
closed ports - 0 to 79, 81 to 138, 140 to 442, 444 & 446 to 65535
hope this helps?
