Checked2013
Expert
Message 11 of 13
Re: HH 5 won't connect to Windows 10 after heavy usage
@sjonez I was referring to the fact the OP was using 2.4Ghz wifi and that's why I have said it would be better to upgrade the wifi
sjonez
Message 12 of 13
Fair enough but I suspect the issue is in the HH itself rather than a bandwidth problem, especially as it prevents any new connections once the issue occurs.
Checked2013
Expert
Message 13 of 13
I suspect that it's because the wifi network is going into ad-hoc mode that the OP is having issues with HomeHub and hence why I've said the things I have.
