teakbank12
Message 1 of 6
HH2 & Sky wireless On Demand box loss of connection to On Demand
I used to have no trouble downloading via Sky On Demand using the wireless box back to a Home Hub 2.
Virtually every time we try & download via On Demand it fails after a while resulting in my other wireless items (tablet) losing connection. My main PC is wired.
When i go in the Sky settings it reads:
Connection to Broadband Router OK
Connection to On Demand FAIL
Running a cable from router to Skybox is not an option although i do have one of those powerline extenders for use with my Smart TV.
Why does this happen?
Did wonder if there is not a fix to use the powerline extender used for my Smart TV to connect to Skybox instead as we rarely use Smart TV functions.
Just desperate to be able to use On Demand again 🙂
Tags (2)
5 REPLIES 5
Message 2 of 6
Re: HH2 & Sky wireless On Demand box loss of connection to On Demand
If the two are next to each other, then simply add a cheap Ethernet switch at the end of the powerine adapter link, as shown in this example here.
http://forumhelp.dyndns.info/networking/powerline3.jpg
You will have four ports you can use, so you connect the TV and the Sky box, and still have two spare ports.
teakbank12
Message 3 of 6
Will investigate this option Keith.
I did change the hub setting from automatic channel to fixed & opted for CH6, downloaded OK tonight & will try again tomorrow to see if this has fixed problem.
Message 4 of 6
Wireless interference could cause connection problems. There are actually 13 wireless channels to choose from, once the hub is set to manual channel selection.
teakbank12
Message 5 of 6
Keith
Sorry for not replying sooner but I've waited to test my theory.
No problems at all since I opted to fixed channel on my hub as opposed to allowing automatic selection, wife now happy!!!
Message 6 of 6
Excellent Smiley Happy
