nigma
Message 1 of 5
HH3 Cannot forward multiple ports to same port number of different machines
I run remote desktops on multiple machines at home.. which are all on port 3389.
I can set-up a single forward from 3389 to 3389, but when for example I try to add a second forward from say for example 3390 to 3389 on a different machine, I'm told by HH that this port is already bound.
I don't want to change the port on each of the machines if I can help it as I might start to loose track of what i've changed.
Any thoughts ?
4 REPLIES 4
Message 2 of 5
Re: HH3 Cannot forward multiple ports to same port number of different machines
I don`t think you can do that, I think I came across that problem on my HH1 as well, so I just used different ports on each machine, an it works fine.
You just need to keep a note of which ones use which port.
I do not use 3389 anyway, as that is a well  known port number, and a target for hackers.
nigma
Message 3 of 5
Thanks.
It's a shame that the HH3 can't handle that - seems like a bug!
I don't really use 3389 anyway (used it as an example). However, I do like to keep the port numbers on the machines as they should be.. i.e. 3389 on the PC but set-up a forward of 53389 to 3389. Makes it much simpler to maintain.
Message 4 of 5
I have never tried it with a different router, but it could be simply a limitation with NAT itself, its not something I have really thought about. But trying to forward the same port, to two different MAC addresses, would require a more complex bit of software than in the average router.
The Home Hub 1 for instant, only allows one entry against each target port, according to the config file.
assign name="HTTP Server (World Wide Web)" host=192.168.1.56 log=disabled
It will not allow the same destination port to be allocated to a different IP address, which is what you are tring to do.
It does not matter if you translate the port number, the destination port will always be the same.
I would expect this to be the same for the other home hubs, and other routers as well.
anthonyUK
Expert
Message 5 of 5
Hi Nigma,
Rather than opening multiple ports for RDP access have you thought about a VPN or an SSH tunnel into your home network?
Much more secure and only one port is normally required to be opened.
