Moderator
Moderator
Message 531 of 555
Re: HH3 - Infinity - Local WiFi Channel 'fade'?
Hi George_Everdell and Enregalian,
Thanks for posting. I’m sure we can help with this. Can you send over the following details?
Telephone number:
Serial number of hub connected:
A few words describing your experience (How often does this issue appear?
How long does it last?
have you found any workarounds?
What impact does it have on your connection?
You’ll get the contact link in my profile.
Cheers
David
CSP74
Message 532 of 555
just sent a message to moderators as having exactly the same issues as everyone here for the past few months,  Fingers crossed
Message 533 of 555
@CSP74
Sending a PM does not normally get a response from the mods as you need to get invite to use the contact us link
did you check your hub was a 'B' version?
CSP74
Message 534 of 555
hi, i got a message back from moderator with link to contact form so thats away off to them.  Not sure if hub is a b version - how do i find out @imjolly?
Cheers
Tags (1)
Message 535 of 555
You need to check the label on the back/bottom. This fix is only for the 'B' version
CSP74
Message 536 of 555
cheers @imjolly - just checked - its a b model 🙂
Message 537 of 555
Just wait on mods getting back to you which at the moment can take 5/6working days excluding weekends
PhilBodley
Newbie
Message 538 of 555
Same as everyone: Home Hub 3 version B WiFi fades from 40Mbs to 1Mbs over half a day following reset. Wired connections ok.
Tried everything suggested.
Please, please will a moderator advise how to fix?
rebelkc
Message 539 of 555
Well a few months down the line am back to square on ...... resetting hub nearly every day again 😞
m0nster
Message 540 of 555
Same problem here =\ Fix no longer working.
