Willstar
Message 1 of 3
HH3 time decided to reset itself
This morning my wifi didn't turn itself on.  For some inexplicable reason instead of the 8th of May 2012 at 7:30am, the home hub decided that it was 5 past midnight in 2003...
Unfortunately I have the time set to “manual” since BT *still* haven’t resolved the daylight saving time issue on the network time server option.
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: HH3 time decided to reset itself
Hi Willstar,
That does seem a bit strange. Did you get your Wifi working again after a reset?
Cheers
Paddy
CB75
Message 3 of 3
Hi, I wonder if you had a power cut at some point? Only my hub did this only a few days ago after we had a power cut! Took me ages to work out why my hub kept turning itself off every few minutes, until I looked at hub stats and found the time had gone back to midnight in 2003 as well! Due to my hub being set to power off at night, it kept turning off thinking it was night!!
I have had to set my timing to manual, as the other ones don't set it to the right time.
