jackiegolf
Message 1 of 2
HH5 Infinity Connections
I have had continuing problems trying to get broadband connection on my IMAC desktop ever since the new Home Hub 5 arrived 3 months ago, prior to which I had no problem with HH4.  BT Vision works well and also two Ipads where ever they are in our apartment.  However, connection to the internet via my desktop computer is a nightmare.  When I have telephoned BT and used their technical help, somehow I manage to get a connection, but after a day or so I switch on and again no connection.  I have a list of various networks on my computer, but when I try and connect with my own HH5 it usually cannot be done and will not accept my password.  I have had my computer checked by Apple who say there is no problem.  The HH5 is located adjacent to the TV in a different room to the computer and there is an outside wall between the two.  What is so strange is that I am now connected via BT Fon, as I cannot connect via HH5.  BT will not replace the HH5 or send a technician or give me any other advice, as they say that wi fi is connected, because of my Ipad connections.  Can anyone suggest something?
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: HH5 Infinity Connections
Hi Jackiegolf,
Welcome to the community forum. You could try Changing The Wireless Channel to see if that helps. If that doesn't work you could try setting up a different network names (SSIDs) for the 2.4GHz and the 5GHz bands.
Take a look Here for more information how to change the SSID's.
Paddy
Community ModeratorPaddyB
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
