Message 11 of 21
Re: Draytek or ZyXel HH5 Replacement
@nujjer Its not a feature I use, but the TP Link has the ability to enable or disable SIP ALG, see screenshot.
TimCurtis
Recognised Expert
Message 12 of 21
I use an Asus DSL-AC68U which overall I find to be excellent.
Regarding the SIP stuff , it has SIP passthru - whatever that means.
nujjer
Message 13 of 21
Excellent insight - thank you
Barry57
Expert
Message 14 of 21
Unlocked Openreach modem and Linksys is my set up.
Also beening looking at Asus AC56/68U (The dual core ones l believe) as a replacement if the linksys ever goes pop...
I still think a separate modem and router set up is a better option than a combo device.
Is Guru  licquorice still  front ending the Tp-link with an unlocked hg612 3b ?
Message 15 of 21
Only to get the stats. The only downside to TP Link, lack of stats.
wedd1ng528
Message 16 of 21
I believe a separate router and modem will also allow you to change/switch off/fiddle with the router without upsetting your connection speed (Dslam continues to see the modem).
Mistakes and embarrasing goofs in e-mails are only discovered when you've sent them!
nujjer
Message 17 of 21
@licquorice I got the TP-Link. Cant get it to connect to DSL. I used settings here - http://bt.custhelp.com/app/answers/detail/a_id/7447/~/how-do-i-set-up-my-non-bt-router%3F
Initialises then goes back to Disconnected.
Can you post your WAN settings please?
Message 18 of 21
It is a PPPoE connection for Infinity.
nujjer
Message 19 of 21
thanks gg..
In other threads it seems I may have bought the wrong fffffflippin' thing.
I have Infinity so want to replace HH5.
I bought W8980 which is (I now find) an ADSL+ Modem router.
I know I'm off topic for this thread now so I'll flip over to the correct one.
https://community.bt.com/t5/Connected-Devices-Other/HH5-replacement-TD-W8980-or-TD-W9980/m-p/1435759...
planetf1
Expert
Message 20 of 21
Just a note on SIP...
I've not noticed problems using a Linksys SPA3102 sip gateway alongside my BT HH5a - it appears to work fine.
Not noticed any user setting to enable/disable any SIP ALG,
Also I've run some sip apps on laptop/tablet without difficulty
I'm using poivy as the sip provider.
