lancasd
Newbie
Message 1 of 7
HH5 as a slave to HH6?
I have looked through the forum and found some suggestions/instructions but wondered if there was anything specific to having a Smart Hub 6 as the master (I've just replaced my old HH5 with it) and using the old HH5 via an ethernet cable as a slave/extendor to my shed in the garden.
I had this set up with the HH5 as the master and an HH4 as the slave in the past.
The reason I'm asking is some of the older instructions aren't quite what I am seeing on the hub(s) - e.g it took me a while to find the dhcp bit of the new hub!
Any advice/suggestions, gratefully received and my apologies if I've missed the same question elsewhere on the forum.
6 REPLIES 6
Message 2 of 7
Re: HH5 as a slave to HH6?
The principles are exactly the same regardless of routers used.
smf22
Recognised Expert
Message 3 of 7
You might have a better experience if you do it the other wat around ie., Hub 6 as slave to Hub 5. The Hub 6 has so many issues at the moment.
Regards
lancasd
Newbie
Message 4 of 7
Thanks very much
splinter
Message 5 of 7
Could you send me the details on how to use my hh5 as a wireless access point to the hh6
splinter
Message 6 of 7
Can you send me details on how to connect my hh5 as a slave to hh6 so that i can put my hh5 in the garaage and connect to wirelessly through the hh5 to the internet
Message 7 of 7
Its extremely simple, just disable DHCP on the HH5, give it an IP address outside of the DHCP range of the HH6 and connect any LAN port on the HH6 to any LAN port on the HH5.
