marco63
Message 1 of 12
HH5 keeps dropping and reconnecting wifi
Subject says it all really. It's been happening for a few weeks for laptop (2.4) and ipad (5)
Here are the helpdesk details
1. Product Name: HomeHub5
2. Serial number: +076286+1519000371
3. Firmware version: v0.07.05.0A13-BT (Type B) Last updated 24/12/2015
4. Board version: 01
5. VDSL uptime: 5 days, 00:44:53
6. Data Rate: 9999 / 40000
7. Maximum Data Rate: 30129 / 91159
8. Noise Margin: 22.3 / 20.3
9. Line Attenuation: 14.9 / 13.3
10. Signal Attenuation: 0.0 / 0.0
11. Data sent/received: 549.5 MB / 8.2 GB
12. Broadband username: bthomehub@btbroadband.com
13. BT Wi-fi: Yes
14. 2.4GHz wireless network/SSID: BTHub5-C7KC
15. 2.4GHz wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4GHz wireless security: WPA2 Only (Recommended)
17. 2.4GHz wireless channel: 3
18. 5GHz wireless network/SSID: BTHub5-C7KC5
19. 5GHz wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5GHz wireless security: WPA2 Only (Recommended)
21. 5GHz wireless channel: 36
22. Firewall: Default
23. MAC Address: 5c:dc:96:48:5f:bb
24. Software variant: -
25. Boot loader: 0.5.0-BT (Tue Jun 17 18:52:56 2014)
11 REPLIES 11
Message 2 of 12
Re: HH5 keeps dropping and reconnecting wifi
The first things to try are to make sure you turn off "smart setup" on the Homehub.
See link how to do that.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/switching-smart-setup-on-and-off-on-the-bt-ho...
Some devices have a problem with the Homehub dual band having the same SSid (name). Try giving the 2.4Ghz and 5Ghz frequencies different SSids. Just add a 5 to the end of the 5Ghz SSid so you know which is which. Check the 5 GHz Sync with 2.4 GHz: is set to NO.
Once you have done that "forget" the connection on your devices and then restart the devices and log onto both the SSids if the devices can use both frequencies. Not all devices can use 5GHz.
See this link
http://bt.custhelp.com/app/answers/detail/a_id/44798/~/i-have-problems-connecting-5ghz-and-dual-band...
marco63
Message 3 of 12
Hi - thanks for the quick reply. I did all your suggestions some months back. This problem has been happening for the last few weeks
Cheers
Mark
Message 4 of 12
have you changed hub lease time to 21 days from the default 1 day.
shamus1
Expert
Message 5 of 12
i expect it started around the time you got the new software on hub 5b as sounds like issues i had when hub 5b upgraded to latest software.
marco63
Message 6 of 12
No I haven't changed that, but I could change it to 1 day
EDIT: I have just checked and it is set for 1 day. Not quite sure why you thought it wasn't
marco63
Message 7 of 12
Shamus, have you resolved your issue yet? Looking at the data it does seem to coincide with the FW update (although I can't be 100% certain of this)
shamus1
Expert
Message 8 of 12
i did go back to a hub 5a but have put hub 5b  back in as it is a far better router,the disconnects of the internet have stopped but wifi kept  disconnecting,what i have done now is manually select wireless channels and seems to be better as regards to wireless drop outs.also when i had hub 5 a   working it was also suffering the same wireless dropouts so am quite sure it is interference at my home thats why i have turned smart wireless off.
Message 9 of 12
the intention was to change from hub default of 1 day to max 21 days so only renews lease every 21 days
marco63
Message 10 of 12
My bad, I've done that now. Thanks.
