mjn500
Newbie
Message 1 of 2
HH5 needs to be manually restarted after connection drops
We have a very slow connection that frequently drops (old wires / trees / far from exchange) but have found in the last week or so that the Hub has to be manually reset in order to reconnect.
It's a cable connection and has been fine since we switched ISP in January due to chronic connection issues. There's nothing obviously wrong with the setup and it was stable for a good 10 weeks, with no change to kit to cause the issue.
There isn't always someone here and we have security cameras linked to the system so this is a bit of a pain!
Mel.
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: HH5 needs to be manually restarted after connection drops
Hi mjn500,
Welcome and thanks for posting. I can look into this for you. Drop me an email with the details. You'll find the "contact us" form in the about me section of my profile. Once I have the details we'll take it from there.
Cheers
David
