rodleydragons
Message 1 of 2
HH6 - Wi-fi dropping out on certain devices??
We just had our home hub 5 replaced after it was shown as faulty.. and have been sent the HH6.
Plugged it in today and all seemed fine (other than the speeds are slower but I assumed that will increase in a day or so)  We have 4 sons all with tablet/phone and 3 xbox ones all of which connected perfectly fine to the HH%... but the wi-fi is dropping out on some of the devices now we swapped to HH6??
Is there anything I need to change in it so it works on all devices??  I am sure i read somewhere about some devices using diferent settings??
I tried the online help with BT Customer services and they said it was "wireless interference" probably... however the device that is currently dropping out is literally 4 foot from the router.. with other devices upstairs working perfectly!!.. so that certainly can't be a case can it?!?!
Any help would be great... if not I will have to go back to the faulty HH5 .. which even when faulty seemed to work better than this one Smiley Sad  thanks
1 REPLY 1
Message 2 of 2
Re: HH6 - Wi-fi dropping out on certain devices??
Make sure you turn off "smart setup" on the Homehub.
See link how to do that.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/what-is-smart-setup-on-the-bt-hub%3F-how-can-...
Some devices have a problem with the Homehub dual band having the same SSid (name). You should try splitting them.
See link
http://bt.custhelp.com/app/answers/detail/a_id/56419/~/how-do-i-split-my-bt-hubs-ssid-%28wireless-ne...
http://bt.custhelp.com/app/answers/detail/a_id/44798/~/i-have-problems-connecting-5ghz-and-dual-band...
