portunus
Message 1 of 24
HH6 resets etc
This seems to crop up a lot. Have the smart hub, home hub 6. It keeps resetting and rebooting. As a result speed drops from 12.35/54.96 Noise 6.1/6.1, (max 12.48/55.7) and is now  12.19/46.43. The line is quiet.  The last engineer visit 27th july resolved a line fault on the pole! The speed is now at its best! It was dropping before that and still continues.
What is the best remedy? I'd think a new hub is the best course? I note some buy a new router, is it that bad to solve?
Thanks for any information
Doug
23 REPLIES 23
portunus
Message 2 of 24
Re: HH6 resets etc
Can I reply? Meant to add, how do I get the line 'reset' Is there a contact or does this need a full engineer carry on?
portunus
Message 3 of 24
Re: HH6 resets etc
Can I reply to myself? Actually mean to add can this line be 'reset'? Is there a contact or does it need to go through whole enginner process? Thanks.
Moderator
Moderator
Message 4 of 24
Re: HH6 resets etc
@portunus can you post your router stats and we'll take a look?
portunus
Message 5 of 24
Re: HH6 resets etc
00:00:56, 01 Jan.
BR_LAN:The DHCP options that are offered by the device (id:3): DiscoverOptions: | DiscoverOption55: | RequestOptions: 53,61,50,54,57,55,60 | RequestOption55: 1,3,6,12,15,28,42 | HostName: | VendorId: udhcp 1.18.5.18.5
00:00:53, 01 Jan.
BR_LAN:UPnP functionality has been activated
00:00:52, 01 Jan.
:DHCP Confirmation of Request
00:00:43, 01 Jan.
:This Rule has been applied successfully: [id:1, InternalClient: , External Ports:(0,0), Internal Ports: (0,0), Protocol: ]
00:00:43, 01 Jan.
:Updating port mapping rule (1) by UPnP
00:00:42, 01 Jan.
eth2:An Ethernet port is now connected (3/100/FULL)
00:00:40, 01 Jan.
BR_LAN:The LAN DHCPv6 Server is active
00:00:40, 01 Jan.
:The LAN DHCP Server is active
00:00:39, 01 Jan.
BR_LAN: Allocated prefix = fdaa:bbcc:ddee::/64 (valid time = 4293967296 / preferred time = 4293967296)
00:00:39, 01 Jan.
:DNS name resolution is now active
00:00:38, 01 Jan.
wl0:WLAN has been deactivated (BTWifi-X) (band : 5GHz).
00:00:38, 01 Jan.
wl0:WLAN has been deactivated (BTWifi-with-FON) (band : 5GHz).
00:00:38, 01 Jan.
wl0:WLAN has been activated (BTHub6-GF2G-5) (band : 5GHz).
00:00:38, 01 Jan.
wl1:WLAN has been deactivated (BTWifi-X) (band : 2.4GHz).
00:00:38, 01 Jan.
wl1:WLAN has been deactivated (BTWifi-with-FON) (band : 2.4GHz).
00:00:38, 01 Jan.
wl1:WLAN has been activated (BTHub6-GF2G) (band : 2.4GHz).
00:00:36, 01 Jan.
Default:Firewall change to Level: FRWL
00:00:36, 01 Jan.
wl0:(0/44) Channel Hopping initiated/Manually initiated
00:00:36, 01 Jan.
wl1:(0/1) Channel Hopping initiated/Manually initiated
00:00:35, 01 Jan.
:The Modem has successfully powered up
00:00:35, 01 Jan.
:WDG Laststatus:: # Current boot was caused by Soft Reset (SAAF)
00:00:28, 01 Jan.
:The Modem underwent a warm reset
00:00:24, 01 Jan.
HI
Thanks for getting back, heres a bit from last reset, around 2days 20 hrs
Limited to 20k characters here. Let me know what bits are needed!
Cheers Doug
:WAN: ethernet as LAN
17:21:12, 23 Aug.
dsl:VDSL Link Down: duration was 842647 seconds
17:21:12, 23 Aug.
:VLAN VLAN_DATA disconnected
17:21:11, 23 Aug.
:Connection to the Internet has been terminated.(Reboot,Reconfiguration,forced termination)
Moderator
Moderator
Message 6 of 24
Re: HH6 resets etc
Hi @portunus
Thanks for posting back!
We need a little more info that that.  Access your Smart Hub's manager (192.168.1.254) and choose Advanced>Technical Log
Post back with a screenshot of that page and we'll take it from there.
Cheers,
Robbie
Message 7 of 24
Re: HH6 resets etc
it's the technical log information not the actual log
Message 8 of 24
Re: HH6 resets etc
portunus
Message 9 of 24
Re: HH6 resets etc
HI
Thanks again for taking time to reply, appreciated. Here's that page:
Product name:
BT Hub 6A
Serial number:
+084316+NQ70220037
Firmware version:
SG4B1000B540
Firmware updated:
16-May-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
3 Days, 15 Hours 6 Minutes 45 Seconds
Data rate:
12.19 Mbps / 46.43 Mbps
Maximum data rate:
12604 / 54843
Noise margin:
6.4 dB / 6.3 dB
Line attenuation:
19.6 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
4354 MB Uploaded / 9490 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Not active
2.4 GHz wireless network name:
BTHub6-GF2G
2.4 GHz wireless channel:
Smart (Channel 6)
5 GHz wireless network name:
BTHub6-GF2G-5
5 GHz wireless channel:
Channel 44
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
A4:08:F5:7F:75:7D
Software variant:
Boot loader:
7.33.1
Moderator
Moderator
Message 10 of 24
Re: HH6 resets etc
Hi @portunus
Thanks for posting back!  That's exactly what we're looking for Smiley Happy
Is the connection still dropping out?  I can see the current network uptime is 3 days 15 hours.  Provided the connection remains stable DLM should automatically improve the speed again.  However, there isn't much of a speed difference between what you had and what you're currently getting so this process can take a few weeks.  Your best bet would be to keep the service connected as much as possible and avoid any manual resets.
If after this time you're still not seeing an increase then we can certainly have another look for you.
Cheers,
Robbie
