portunus
Message 21 of 24
Re: HH6 resets etc
Hi
Missed out last bit of text last message! The speed is not really the issue, it is the frequent resets of the HH6, this does impact on speed some what. Is a switch from type a to tybe b hub worth a go?
Thanks!
portunus
Message 22 of 24
Re: HH6 resets etc
Just wondering what other users system/network uptimes are on the HH6. Mine are around 10 days ish before resets etc.
Message 23 of 24
Re: HH6 resets etc
many posts before the reset time was 14 days - mine was 14 days like clockwork - then all of a sudden it stopped and now my resets are drop in power or manual reset as I make changes
the hub droppng conenction every 10 days will not impact on your conenction speed or noise margin
portunus
Message 24 of 24
Re: HH6 resets etc
Hi
Thanks once more. I am not sure this copy  from the HH6 log shows the disconnects, I searched from WAN. It does seem to suggest the probelm is getting worse. It's a rwal pain now. Comments and suggestions as always welcome.
Many Thanks
21:27:48, 21 Mar.
:WAN: SENSING AUTO VDSL
21:27:38, 21 Mar.
ptm0.101:VLAN VLAN_DATA connected
21:27:37, 21 Mar.
:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
21:27:37, 21 Mar.
:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
21:27:37, 21 Mar.
dsl:VDSL link Up: Down Rate=53711Kbps, Up Rate=11974Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
21:27:19, 21 Mar.
:VLAN VLAN_DATA disconnected
21:27:10, 21 Mar.
dsl:VDSL Link Down: duration was 12413 seconds
18:00:30, 21 Mar.
18:00:18, 21 Mar.
18:00:18, 21 Mar.
18:00:18, 21 Mar.
18:00:18, 21 Mar.
dsl:VDSL link Up: Down Rate=53795Kbps, Up Rate=11907Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
17:59:57, 21 Mar.
17:59:50, 21 Mar.
dsl:VDSL Link Down: duration was 82568 seconds
19:03:54, 20 Mar.
19:03:44, 20 Mar.
19:03:43, 20 Mar.
19:03:43, 20 Mar.
19:03:43, 20 Mar.
dsl:VDSL link Up: Down Rate=53621Kbps, Up Rate=12086Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
19:03:25, 20 Mar.
19:03:16, 20 Mar.
dsl:VDSL Link Down: duration was 61447 seconds
01:59:20, 20 Mar.
01:59:10, 20 Mar.
01:59:10, 20 Mar.
01:59:10, 20 Mar.
01:59:10, 20 Mar.
dsl:VDSL link Up: Down Rate=54553Kbps, Up Rate=12075Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
01:58:52, 20 Mar.
01:58:42, 20 Mar.
dsl:VDSL Link Down: duration was 1803 seconds
01:28:53, 20 Mar.
01:28:41, 20 Mar.
01:28:41, 20 Mar.
01:28:41, 20 Mar.
01:28:40, 20 Mar.
dsl:VDSL link Up: Down Rate=54068Kbps, Up Rate=12172Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
01:28:22, 20 Mar.
01:28:13, 20 Mar.
dsl:VDSL Link Down: duration was 426944 seconds
