Anonymous
Not applicable
Message 1 of 12
HInternal network details and dashboard accessible on WAN interface
It appears that information internal to my network is freely available simply by visiting my ip address. WITHOUT A PASSWORD.
MAC addresses, hostnames, ip addresses... the lot...
I am absolutely beside myself. How do we restrict access?
11 REPLIES 11
Anonymous
Not applicable
Message 2 of 12
Re: HInternal network details and dashboard accessible on WAN interface
On the phone to "tech support"... not inspiring the greatest confidence.
Anonymous
Not applicable
Message 3 of 12
We've sorted it out they didn't even know this was possible.
Bug.
Message 4 of 12
You need to be connected to your home network before you can see that information
Message 5 of 12
No it isn't.
Anonymous
Not applicable
Message 6 of 12
Yes it is. Go to your dashboard on your public IP and select "My Devices".
Message 7 of 12
Use you mobile but turn off wfi then try using mobile network entering 192.168.1.254 into address bar and see if you can access hub without password
Anonymous
Not applicable
Message 8 of 12
Friend. Please.
You're talking to a veteran here. 192.68.x.x is the private IP which is accessible through the wifi.
Do me a favour, go to google and type "what is my ip" then enter that number into your browser as "https://<your PUBLIC ip>
Then view your information, freely available.
Message 9 of 12
Next time try to come up with a useful response.
I can assure you that it is not possible to access the hub manager via your public IP address. If you are connecting via your own wifi rather than a 4G or other method you will be simply performing a NAT loopback within the hub from your private IP address.
That is a useful response.
Anonymous
Not applicable
Message 10 of 12
Except it's wrong.
Please stop wasting my time. I've tested this across a number of devices from a few different locations now.
