warby1
Message 1 of 6
HP Printer can see 'BTWIFI' but not my network SSID
Hi, I have a HP printer which I'm trying to setup using the HP wizard.  When I get to the bit where it wants to connect to available networks it can see some neighbours networks (weak) and my router's public BTWIFI network SSID (strong) but not my own SSID.  Any ideas?  Thanks
5 REPLIES 5
warby1
Message 2 of 6
Re: HP Printer can see 'BTWIFI' but not my network SSID
and smart setup is off!
licquorice
Message 3 of 6
Try splitting the WiFi bands if you have anything other than a Smart Hub 2. If you have a SH2, temporarily turn off the 5Ghz WiFi, connect the printer and then restore the 5Ghz signal.
http://bt.custhelp.com/app/answers/detail/a_id/56419/~/how-do-i-split-my-bt-hubs-ssid-%28wireless-ne...
warby1
Message 4 of 6
Thanks but no luck. Phone can see separate SSIDs now but printer only sees the public BTWIFI network.
licquorice
Message 5 of 6
That is totally weird, does it see the SSIDs if you temporarily turn off the security (WPA2)?
gg30340
Message 6 of 6
Can other wireless devices see your hub's SSid?
Just noticed that you have stated they can see the SSids.
