jonew
Message 1 of 3
HP pavilion "limited connectivity" on hh3
HOWS IT GOING ALL
As the title says,I have limited connectivity on my HP pavilion laptop which I recently bought,I've tried the obvious like updating drivers,uninstalling etc yet I still have the same issue.. I've also tried changing wireless channel on the hh3.
I run iphones,tablets etc with WiFi with no issues at all..
Can anyone help??..
2 REPLIES 2
Message 2 of 3
Re: HP pavilion "limited connectivity" on hh3
It could be that your computer has IPv6 selected. Try disconnecting it as follows:
Select Start
In the search field type.ncpa.cpl and press enter.
In the new window right click on your wireless network connection and select properties
In “This connection uses the following items” section remove the tick beside Internet Protocol Version 6 (TCP/IPv6) then press OK
Left click on Internet Protocol IPv4, click properties . Check the options to obtain IP address and DNS server address automatically.
Once done try and connect to internet.
jonew
Message 3 of 3
Thank u so much
So far so good,really appreciate the help..
