Message 1 of 5
Halifax online
Hi there I’m having trouble accessing my online banking on my phone as well as from my laptop have been told it’s sonething to do with my internet settings? Anyone advise what I can try? It looks like there’s a block somewhere when I try to access the app and website ?
4 REPLIES 4
Message 2 of 5
Re: Halifax online
Both working fine for me, although I don't use a BT router. Can you access on the phone if you switch off WiFi & connect via mobile data?
** I'm no longer active on the forums. **
Message 3 of 5
Re: Halifax online
Nope the apps don’t work either way with wifi turned on or off
Message 4 of 5
Re: Halifax online
Then I'd suggest the problem lies with your account rather than the connections.
Although if you're using antivirus software on the phone I'd try disabling it.
Message 5 of 5
Re: Halifax online
BT managed to do a hard reset and finally working!! Thanks for advice
