Message 1 of 3
Halo 3 wifi kit
Hope i am on the corrrect board...
If i purchase a new BT2 smart hub and wi-fi disc  online in an attempt to get better wifi, is just a case of plug and play after following the setup process ?
(Realise there would be no BT backup for it)
2 REPLIES 2
Message 2 of 3
Re: Halo 3 wifi kit
Yes, plug and go is all you need, the discs will include instructions to pair up.
Message 3 of 3
Re: Halo 3 wifi kit
I would research better alternatives before buying.
