janlegg
Message 1 of 3
Halo Hub and Networks
Hi
I have recently upgraded to Halo 2.
My connections include a PC and two WiFi Laptops.
The PC is connected via ethernet cable Network name "Network 2"
The two Laptops connect via WIFI and have a different Network name (the name if the hub).
The networks of the PC and the Laptops are not visible to each other.
I am running Windows 10 Home on each computer.
I can see the Laptops and their shared files on the PC but can't see the PC or its shared files on the Laptops.
All are showing as connected etc on BT virus.
Specifically the Laptops cannot see/connect to my HP Desktop 9800 printer that is non-WiFi and connected directly to the PC.
The BT Hub that I used prior to the upgrade did allow sight/connection to the printer by the Laptops.
I have tried most routines I can find on the internet that don't require additional equipment or software unsuccessfully.
I had a long discussion with BT Tech who were also mystified and suggested I put this on the forum.
Jan
2 REPLIES 2
imjolly
Message 2 of 3
Re: Halo Hub and Networks
have you gone to the network and sharing centre on pc/laptops and ensure they are set up to share with other devices
is your network shown as private not public?
janlegg
Message 3 of 3
Yep setup to all to share etc and tried both public and private network
