piccadilly
Message 1 of 4
Have to keep re-entering password
Good afternoon.
We operate 2 iPads via our BT broadband.
They work fine for a short while - then stop connecting ,although the three sector wireless symbol at the top of the iPads is strong - and in settings the hub code has a tick next to it.
We have to forget the network - then reinput the wireless key and they start working again for a short while  - then the process has to repeated.
Any suggestions.
Kind Regards.
3 REPLIES 3
gg30340
Message 2 of 4
Re: Have to keep re-entering password
Make sure you turn off "smart setup" on the Homehub.
See link how to do that.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/what-is-smart-setup-on-the-bt-hub%3F-how-can-...
piccadilly
Message 3 of 4
Hello.
Thank you for your prompt reply - I have tried what you suggest but still the same situation.
SIRI however continues to work!
It could be a problem with the iPad - but strange they both do the same thing.
gg30340
Message 4 of 4
