isdoo
Message 1 of 1
Having issues with port 5065/5060 - home hub 5
Hi,
Am all of a sudden having issues with people hearing me on a voip phone. I can hear them fine.
If I disable the firewall a test call works fine and my voice is recorded and played back.
My inbound is on port 5060 and the outbound on the two phones is 5065
I have never had to set port forwarding on ports 5060 / 5065 etc. before and it has worked fine.
I can set up port forwarding on 5065 to one phone, but then it would not work on the other, I guess.
A bit confused. Have checked that parential controls etc., are off as is smart setup.
What I have noticed is that neither phone is showing on the list of devices on the hub. Despite them both 'working'. i 'think' they were showing previously.
Not sure what has suddenly gone wrong.
