Solved! Go to Solution.
The colour of the Ethernet cables are irrelevant so do not worry about that.
If you have a white Openreach modem you can do away with the Openreach modem that is plugged into the phone socket.
You just plug the Smarthub into the phone socket using the "telephone" cable .
See link
