k1ano
Message 11 of 13
Re: Help Regarding Y-Cam Evo (ip camera) on Home Hub 6
I’ll keep trying different things to try and get to root cause and of course post back any findings ...
k1ano
Message 12 of 13
Bit of info I need to try next ...
Spoke to a technical guy at Y-cam who firstly said go back to HomeHub 5 ...
But offered some advice/settings below which he has with his HomeHub 6, namely ...
Factory reset.
Split the bands.
Try mode 2, but mode 1 'may' work.
Password no more than 19 characters. This is probably what is causing my issues, I had wondered about this but didn't try making it shorter. Some combinations of special characters may cause issues however.
M
k1ano
Message 13 of 13
Well job done, resetting the router and using the router password (which is less than 19 characters) worked.
So I decided to ditch my own SSID and password and keep it simple with the factory settings.
M
