Jackirate
Message 1 of 36
Help with Asus DSL-AC68U
Hi Everyone,
I’m looking for a hand setting up my new ASUS DSL-AC68u to replace my HH5
Everything is connected correctly, I have ran through the set up wizard using the correct credentials. (bthomehub@btbroadband.com / BT)  but I am still getting internet status showing as disconnected?
What would be the first things to check? I feel like I’m being an idiot here as searching the forums most people with this device at least managed to connect up.
Any help would be greatly appreciated, if anyone needs any more information feel free to ask and I’ll reply as soon as I can to the best of my ability.
Thanks in advance!
35 REPLIES 35
imjolly
Message 2 of 36
Re: Help with Asus DSL-AC68U
previous forum post  https://community.bt.com/t5/BT-Fibre-broadband/ASUS-DSL-AC68U-CORRECT-SETTINGS/td-p/1839925
Jackirate
Message 3 of 36
Hi thanks for the reply.
I have configured the dsl settings to the ones suggested in that post but I’m still getting a status of disconnected with no internet light showing on the router.
Is there anything else I can try?
imjolly
Message 4 of 36
can you post your current settings and someone may be able to assist
h3x1e
Expert
Message 5 of 36
Make sure the VLAN Tag is set to 101
Jackirate
Message 6 of 36
VLAN TAG is set to 101.
I am trying to post a photo of my settings but for what ever reason they won’t upload even after compression. I’ll keep at it
imjolly
Message 7 of 36
are you using the  camera to post your photo of stats
Jackirate
Message 8 of 36
I was having an issue uploading from my phone, ive had to tether my 4g to the laptop to try and upload.. here are my settings. Thanks again in advance.Capture.PNGCapture2.PNGCapture3.PNGCapture4.PNGCapture5.PNG
h3x1e
Expert
Message 9 of 36
is the time and date correct on the Router? If there is such an option
Since it seems kinda 4 years wrong 😛 see if you can change it.
Also you could try setting the Greenwich Mean time to British Summer Time or GMT +1 if there's an option
imjolly
Message 10 of 36
should web access from wan not be yes
