Never mind thats me being stupid I think, the ntp sync issue is probably because there;s no connection -_-
I think Web Access from WAN is just being able to access the config from outside the network
also the password seems like it's 3 characters, make sure it's only BT.
Try changing DSL Modulation to Auto Sync-Up and ANNEX Mode to A/I/J/L/M
Changed the modulation and the password to BT but still have the disconnected status. Hoping I’ve got my set up correct, I have an open reach master socket which i have only. The dsl cable coming from in to the back of the router. I unplugged the house phone years ago so that port is empty.
And nothing shows in the DSL Log tab im guessing?
Nothing that makes any sense to me haha
Seems like it's synced and connected, what device are you trying to access the web from?
looks like showing a connection now for 6 mins
4 day old razor blade 15 laptop. ive tried from an old sony laptop with the same results though.
Still getting this connection error when I try connect via wifi.
Nothing when I try via a wired connection
