Expert
Message 11 of 36
Re: Help with Asus DSL-AC68U
Never mind thats me being stupid I think, the ntp sync issue is probably because there;s no connection -_-
Expert
Message 12 of 36
I think Web Access from WAN is just being able to access the config from outside the network
Expert
Message 13 of 36
also the password seems like it's 3 characters, make sure it's only BT.
Try changing DSL Modulation to Auto Sync-Up and ANNEX Mode to A/I/J/L/M
Message 14 of 36
Changed the modulation and the password to BT but still have the disconnected status. Hoping I’ve got my set up correct,  I have an open reach master socket which i have only. The dsl cable coming from in to the back of the router. I unplugged the house phone years ago so that port is empty.
Expert
Message 15 of 36
And nothing shows in the DSL Log tab im guessing?
Message 16 of 36
Nothing that makes any sense to me haha
Expert
Message 17 of 36
Seems like it's synced and connected, what device are you trying to access the web from?
Message 18 of 36
looks like showing a connection now for 6 mins
Message 19 of 36
4 day old razor blade 15 laptop. ive tried from an old sony laptop with the same results though.
Message 20 of 36
Still getting this connection error when I try connect via wifi.
Nothing when I try via a wired connection
