Recognised Expert
Message 21 of 36
Re: Help with Asus DSL-AC68U
The firmware version is quite old but that shouldn't matter at this point.
Most of the other settings now look OK apart from the UPBO on the DSL settings page. This should be Enabled although again that shouldn't stop you getting authenicated.
Have you tried a factory reset or did you just plug it in and start the setup?
Is the Asus new or been used previously?
Are you still getting those PAD0 lines in the error log?
Message 22 of 36
Hi Tim,
Thanks for the reply.
the ASUS is new, when I unpacked it I tried to plug and play without performing any factory resets.
Are there any more details about my set up that’s could help?
Recognised Expert
Message 23 of 36
@Jackirate
Personally I'd go into Administration/Restore/Save etc and restore to factory defaults and then run through the wizard again knowing what you know now.
Message 24 of 36
Sorry for the simple question but is that just a case of holding down the reset button on the back of the router?
Message 25 of 36
And then shall I run through the quick setup guide or do the lot manually?
Message 26 of 36
All my errors refer to an authentication issue.
i know my pppoe* username and password is correct and it’s the same for everyone on bt correct?
Could this of of been changed any bow for individual users?
I have performed a reset on the router and ran through the process again but identical issues, dsl connection is there but no internet 😞
Message 27 of 36
Thank you for the help everyone I have got it up and running.
Turns out the firmware update is a big deal on these things, who knew? - Updated and it connected instantly, thank you all for your patience, its appreciated!
Recognised Expert
Message 28 of 36
Can you post an image of the most recent lines in the General System log please.
Edit: Ignore this post then.
Do check the UPBO setting and ensure that it's Enabled as this has an adverse effect on any ADSL users around you and could get you banned by OpenReach.
Message 29 of 36
Hello
Can you please send me your setting or screen grab,
Am struggling to follow all the feeds.
Many thanks
Recognised Expert
Message 30 of 36
@supereman
This is my DSL settings:-
Hope that might help.
