Message 1 of 37
Help with asus dsl-ac68u modem router
hey i tried to set it up but when i do it says the dsl isnt pluged in but it is and when plugged into mt bt router it works?
36 REPLIES 36
Sage
Message 2 of 37
Re: Help with asus dsl-ac68u modem router
What service are you connecting it to FTTC or FTTP?
Message 3 of 37
i couldnt get to that part due to it keep on saying dsl not connected
Message 4 of 37
do you have something like this
or just connecting to master socket
Recognised Expert
Message 5 of 37
@GeekGamming
If you're lucky enough to have a G.Fast connection then it won't work.
We really need to understand what plan you're on.
Message 6 of 37
sorry for late reply this is what i am using for my socket 74651268-da7b-42ed-9dce-9c991e2effc1.jpg
Message 7 of 37
wouldnt it be unlucky if i cannot use it because of GFast since i just paid £130 for this 😕
Message 8 of 37
You would need the Asus DSL-AC88U for G.fast.
Message 9 of 37
does this work with vpn's? DSL-AC88U
Message 10 of 37
is it this one ASUS DSL-AC88U AC3100
