Koldershaw
Message 1 of 3
Help with my sky go app
Hi all. Please can other bt wifi users help? Anyone have sky tv and use sky go app or sky sports app on your mobile and tablet? If so can you try to watch live tv on the app using your BT wifi? Does it work? Mine has stopped working and doesn't work on neighbour's BT wifi either, but does work on other company's wifi. It's only live tv not working and catch up is fine. I need some more test samples to know if it's just me or a wider BT issue. Thanks for any feedback positive or negative.
2 REPLIES 2
Message 2 of 3
Re: Help with my sky go app
Hi @Koldershaw   Sky Go on iPad BT WiFi, watching live programmes, no problems whatsoever.
Message 3 of 3
BTWIFI works fine for me
are you a bt broadband customer?
