Distinguished Guru
Message 1 of 6
Here is a puzzle!
HH6 and a normal WiFi speed of 24mbs.
until today all was fine. My TV,iPad Pro and other devices are connecting without a problem.However suddenly our two iPhones a 7plus and a 6 can connect but with download speeds of 0.3. The phones have been reset. The Hub rebooted twice. Occasionally normal WiFi service is resumed on our phones but only briefly. Nothing has changed, no updates, no rearrangement of furniture electrical items or anything that could possibly effect it. Echo Show works will play video, Netflix works via Fire TV but not our phones. My daughter with an older iPhone visited and connected at our normal WiFi speeds.
Any ideas are welcome.
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
5 REPLIES 5
Message 2 of 6
Re: Here is a puzzle!
Hi @stuartrogerson. When you say no updates does that include the firmware on the HH6? Some users have reported problems with iPhones and D038.
Distinguished Guru
Message 3 of 6
I wasn’t aware of the Hub update I never look at it apart from rebooting. I wasn’t aware there had been reports I had a good google but found nothing. Is there a solution?
Helpful Post?
Message 4 of 6
Have you tried changing the wireless mode
Message 5 of 6
Distinguished Guru
Message 6 of 6
Hi @stuartrogerson. I would have a look here:
https://community.bt.com/bt/board/message?board.id=OtherBB&message.id=155977#M155977
Thank you for the link. I now have it working, sort of, on my iPhone 7plus
Helpful Post?
