Message 1 of 8
Hidden network
How can I turn off the hidden network as I am not using BT Whole Home WiFi?
Not only is the hub running hot and wasting electricity.
We can see the network and it asks for a password which we do not know.
Thanks in advance.
7 REPLIES 7
Message 2 of 8
Re: Hidden network
If the hidden network is coming from your Wholehome disks (probably their backhaul) and you're not using them, then just unplug them!
Message 3 of 8
Re: Hidden network
We do not have and never have had any discs plugged in.  The hidden network is constantly broadcasting.
Message 4 of 8
Re: Hidden network
@HelloHorace
Its the backhaul connection for any BT Complete Wi-Fi disks, whether you have any or not.
Message 5 of 8
Re: Hidden network
Hi Keith,
 I know what it is.  As my post states, I want to switch it off because it's not in use, wasting electricity and generating unnecessary radiation.
Thanks.
Message 6 of 8
Re: Hidden network
Unfortunately, you can't.
Message 7 of 8
Re: Hidden network
I don`t think that is possible, maybe there is an option on the BT Smart Hub 2 to turn off Wi-Fi, but you will still have radiation from the DECT base unit inside the hub, and you cannot turn that off.
I suspect most of the heat is simply generated by the rest of the internal hardware.
Some info about power usage https://bt-digital-voice.blogspot.com/p/bt-smart-hub-2.html
Message 8 of 8
Re: Hidden network
Thanks Keith
