Message 1 of 3
Hiding SSID
Hi.  I have the BT hub that has the large circular light with the logo in the middle (not sure of that's important).  I want to turn off SSID and not transmit the network name.  I cannot see anywhere on hub manager where I can do that.  I've looked under 'Wireless'  and I've looked under 'advanced settings' but I just don't see how to turn that off.   Can you please point me how to do that please ?
Thanks.
2 REPLIES 2
Message 2 of 3
Re: Hiding SSID
It's an urban myth, mate.  The SSID can still be obtained easily with the right tools, so you don't gain anything security-wise and potentially it can introduce a load of other problems.  What is useful is changing the default SSID so the type of equipment you're using is not quite so obvious.
Message 3 of 3
Re: Hiding SSID
Exactly that
