Sammi
Message 11 of 16
Re: Home HUb 2 port forwarding problems
Have just disabled the bt net protect and the port is open. Many thanks.
Message 12 of 16
I did suspect that was the problem.
Extra firewalls, especially Netprotect, cause more trouble than anything else, and are not really needed unless you are connecting directly to a cable or Openreach modem.
If you are connecting via a home hub, or other NAT router, then that has its own internal firewall which blocks any incoming connection, unless its part of an existing transaction, or has been allowed through using port forwarding.
Sammi
Message 13 of 16
Many thanks. I must admit to feeling a little exposed without the firewall that I can see. What I don't understand is why everything worked well last year. I must have changed some settings or has the Net Protect been updated to make it more troublesome. Would the windows firewall cause the same problem? I know you are confident about the hub firewall but why won't it forward the port I ask it to? Don't worry about answering these questions I am just thinking out loud.
Message 14 of 16
Netprotect is always giving people problems  Smiley Wink
Windows firewall would need to have exceptions added, to allow the camera to work. It depends a lot on the version of Windows.
Windows XP firewall only needs incoming exceptions to be added, but Windows 7 firewall is more complex, and will block certain outgoing connections as well.
Now you know what is causing the problem, at least you can play aroung with the firewall settings, if you get time. But I would not worry too much, as the home hub firewall and IDS (Intrusion Detection System) is quite efficient, as you would see if you looked in the home hub event log.
Sammi
Message 15 of 16
I thought I would let you know I entered the port in the McAffee firewall settings and things are running well.
I didn't need to do this last time. Must be a Net protect 'improvement' update.
Thanks again
Message 16 of 16
Excellent Smiley Happy
Thanks for letting me know, I will now remove this thread from my "watched" list.
