Honington
Newbie
Message 1 of 2
Home Hotspot 600 ethernet connection to BT Home Hub and PC cripples PC performance
I have connected the Home Hotspot 600 to a BT Home Hub which in turn is connected to a PC via ethernet.
This  slows pc performance to such an extent you cannot type without waiting for individual characters to appear.
What processes are at work here?
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Home Hotspot 600 ethernet connection to BT Home Hub and PC cripples PC performance
Hi @Honington,
Welcome and thanks for posting. It's very unlikely that the extenders would have any affect on your PCs peformance but judt to confirm are you able to connect directly without using them to check if it makes any difference?
Cheers
David
