eltoro_72
Newbie
Message 1 of 7
Home Hotspot 600 issue (cannot connect to DHCP server)
Hi. I have just installed BT home Hotspot and can see the hotspot via wireless. In trying to setup my son's xbox one I keep getting the message "cannot connect to your DHCP server". I have followed all the troubleshooting solutions ie unplugging router for 5 mins etc, but it's still the same. Could anyone advise me please? Thanks in advance.
6 REPLIES 6
Message 2 of 7
Re: Home Hotspot 600 issue (cannot connect to DHCP server)
Are you able to connect anything, such as a phone or tablet and browse the Internet through the hotspot?
Message 3 of 7
Welcome to this user forum. @eltoro_72
Have you tried a factory reset of the home hub?
http://bt.custhelp.com/app/answers/detail/a_id/11386/%7E/how-do-i-reset-my-bt-hub-to-its-factory-set...
You may also like to try connecting the Xbox to one of  the Ethernet ports on the hotspot 600, as that will give you a better connection.
eltoro_72
Newbie
Message 4 of 7
Hi. Good question! I just tried my Mac and my iphone and both *cannot* connect either. I just get 'No internet connection', yet the green lights are lit on the devices. Although... 'Data' on the main unit (connected to Home Hub 5) is not lit.
eltoro_72
Newbie
Message 5 of 7
Hi Keith. Thanks for the welcome.
Yes, I could try re-setting if you think that could work. What settings would I lose though?
The xbox is in a room around the corner from the hotspot, although push comes to shove, I could move it into the room. I was originally intending having it there so my daugher could access it also.
Message 6 of 7
Check the Ethernet cable from the home hub to the hotspot main unit is pushed in fully both ends until they click into place.
If that does not help, try a different port on the home hub, do not use the red one, as that is the WAN connection.
eltoro_72
Newbie
Message 7 of 7
Hi Keith, seems to be working now! Tried re-setting the router, didn't work. But after (again) unplugging for 5 mins, it worked. So seemed to be a combo of them both.
Thanks for the assistance.
