stumac
Newbie
Message 1 of 7
Home Hub 2 has started rebooting regularly
Hi folks, wonder if anyone can help me with a problem that just started last week.
I have a Home Hub 2, type A, on firmware 8.1.H.U.  Small home network of two desktop PCs and one laptop, all running Windows 7 64-bit with all latest updates and Microsoft antivirus, plus a BT Vision box, a printer and a NAS.  Connected with a mixture of ethernet cables, wifi and HomePlugs.  Nothing in this setup has changed recently.
Late last week, the Home Hub started rebooting itself every 17 minutes and 28 seconds (judging by the event logs).  All the lights go off, the hub disappears from the network (so effectively the network goes down in its entirety), then slowly the systems come back online, till 4 minutes later broadband is up and working again for another 13 and a half minutes.  This is repeating like clockwork.
From the event logs, all I can see is that it's doing a controlled restart.  Is there any way of finding out what triggered the restart?
I thought the NAS was the most likely culprit, as I've yet to find a reliable one, so I unplugged that, and it's made no difference.
I've also done the BT line test, which reported no problems (though it came back instantly; last time I did one I'm sure it took a while), and the BT speed tester, which reported about 12Mbit/sec down and 0.96Mbit/sec up.
Attached are the event log and the ADSL status.  I'd be really grateful if anyone can offer any advice.
Cheers
Recorded Events
18:46:50  11 Jul
LOGIN User admin logged in on [HTTP] (from 192.168.1.71)
18:46:08  11 Jul
LOGIN User Basic logged in on [HTTP] (from 192.168.1.71)
18:44:46  11 Jul
SNTP Synchronised to server: 213.123.20.170
18:44:46  11 Jul
SNTP Systemtime update: time setting 01:03:59 > new time setting: 18:44:46
01:02:33   1 Jan
UPnP action 'DeletePortMapping' from ip=192.168.1.66 (Success)
01:02:32   1 Jan
UPnP action 'AddPortMapping' from ip=192.168.1.66 (Success)
01:02:29   1 Jan
01:02:17   1 Jan
UPnP action 'DeletePortMapping' from ip=192.168.1.66 (No such entry in array)
01:02:12   1 Jan
CONFIGURATION saved by TR69
01:01:37   1 Jan
usbmgr: USB device isn't matched the configuration
01:01:37   1 Jan
usbmgr: try /etc/usbmgr/class/module
01:01:37   1 Jan
usbmgr: try /etc/usbmgr/class/09/module
01:01:37   1 Jan
usbmgr: try /etc/usbmgr/class/09/00/module
01:01:37   1 Jan
usbmgr: try /etc/usbmgr/class/09/00/00/module
01:01:37   1 Jan
usbmgr: class:0x9 subclass:0x0 protocol:0x0
01:01:37   1 Jan
usbmgr: buffer line: remove T
01:01:37   1 Jan
01:01:37   1 Jan
01:01:37   1 Jan
01:01:37   1 Jan
01:01:37   1 Jan
01:01:37   1 Jan
01:01:37   1 Jan
01:01:34   1 Jan
LOGIN User Basic logged in on [HTTP] (from 192.168.1.66)
01:01:32   1 Jan
PPP link up (Internet) [86.150.188.251]
01:01:32   1 Jan
PPP CHAP Chap receive success : authentication ok
01:01:32   1 Jan
PPP CHAP Receive challenge (rhost = bras-red7.gw-th)
01:01:27   1 Jan
xDSL linestate up (ITU-T G.992.5; downstream: 14332 kbit/s, upstream: 1161 kbit/s; output Power Down: 21.0 dBm, Up: 12.3 dBm; line Attenuation Down: 24.5 dB, Up: 12.7 dB; snr Margin Down: 6.4 dB, Up: 6.3 dB)
01:01:03   1 Jan
xDSL linestate down
01:00:54   1 Jan
DHCS server up
01:00:54   1 Jan
FIREWALL event (1 of 2): modified rules
01:00:54   1 Jan
FIREWALL event (1 of 1): deleted rules
01:00:49   1 Jan
FIREWALL level changed to Standard.
01:00:45   1 Jan
FIREWALL exact tcp state check (1 of 1): Protocol: TCP  Src ip: 192.168.1.66 Src port: 61904 Dst ip: 64.4.61.218 Dst port: 1863
01:00:44   1 Jan
WIRELESS automatic channel selection done (channel = 7)
01:00:41   1 Jan
FIREWALL event (1 of 8): created rules
00:00:41   1 Jan
DHCR relay: Dropping boot request on inactive interface LocalNetwork
00:00:40   1 Jan
00:00:40   1 Jan
FIREWALL event (1 of 1): modified rules
00:00:40   1 Jan
FIREWALL event (1 of 1): created rules
00:00:29   1 Jan
WIRELESS interface turned on.
00:00:28   1 Jan
usbmgr: start 0.4.8
00:00:19   1 Jan
KERNEL Warm restart
18:40:42  11 Jul
KERNEL Controlled restart
18:40:33  11 Jul
PPP link down (Internet) [31.52.141.196]
18:27:14  11 Jul
18:27:14  11 Jul
SNTP Systemtime update: time setting 01:03:59 > new time setting: 18:27:14
01:02:29   1 Jan
01:02:29   1 Jan
01:02:26   1 Jan
01:02:16   1 Jan
01:02:14   1 Jan
01:01:40   1 Jan
01:01:39   1 Jan
01:01:39   1 Jan
01:01:39   1 Jan
01:01:39   1 Jan
01:01:39   1 Jan
01:01:39   1 Jan
01:01:39   1 Jan
01:01:39   1 Jan
01:01:39   1 Jan
01:01:39   1 Jan
01:01:39   1 Jan
01:01:39   1 Jan
01:01:39   1 Jan
01:01:38   1 Jan
01:01:37   1 Jan
01:01:32   1 Jan
01:01:29   1 Jan
PPP link up (Internet) [31.52.141.196]
01:01:29   1 Jan
01:01:29   1 Jan
01:01:27   1 Jan
xDSL linestate up (ITU-T G.992.5; downstream: 14332 kbit/s, upstream: 1160 kbit/s; output Power Down: 21.0 dBm, Up: 12.8 dBm; line Attenuation Down: 24.5 dB, Up: 12.7 dB; snr Margin Down: 6.6 dB, Up: 6.3 dB)
01:01:03   1 Jan
xDSL linestate down
01:00:55   1 Jan
DHCS server up
01:00:54   1 Jan
01:00:54   1 Jan
01:00:50   1 Jan
01:00:44   1 Jan
01:00:43   1 Jan
FIREWALL exact tcp state check (1 of 1): Protocol: TCP  Src ip: 192.168.1.71 Src port: 49374 Dst ip: 64.4.44.76 Dst port: 1863
01:00:41   1 Jan
00:00:41   1 Jan
00:00:41   1 Jan
00:00:40   1 Jan
00:00:29   1 Jan
00:00:28   1 Jan
usbmgr: start 0.4.8
00:00:19   1 Jan
KERNEL Warm restart
18:23:10  11 Jul
18:23:07  11 Jul
PPP link down (Internet) [86.150.75.32]
18:09:41  11 Jul
SNTP Synchronised to server: 213.123.26.170
18:09:41  11 Jul
SNTP Systemtime update: time setting 01:03:59 > new time setting: 18:09:41
01:02:27   1 Jan
01:02:26   1 Jan
01:02:23   1 Jan
01:02:16   1 Jan
01:02:16   1 Jan
01:01:38   1 Jan
01:01:38   1 Jan
01:01:38   1 Jan
ADSL line status
Connection information
Line state                 Connected
Connection time            0 days, 0:03:01
Downstream                 14,332 Kbps
Upstream                     1,171 Kbps
ADSL settings
VPI/VCI                    0/38
Type                       PPPoA
Modulation                 ITU-T G.992.5
Latency type               Interleaved
Noise margin (Down/Up)     6.9 dB / 6.1 dB
Line attenuation (Down/Up) 24.5 dB / 12.7 dB
Output power (Down/Up)     0.0 dBm / 12.6 dBm
Loss of Framing (Local)    0
Loss of Signal (Local)     0
Loss of Power (Local)      0
FEC Errors (Down/Up)       324 / 0
CRC Errors (Down/Up)       0 / N/A
HEC Errors (Down/Up)       N/A / 14
Error Seconds (Local)      0
6 REPLIES 6
Message 2 of 7
Re: Home Hub 2 has started rebooting regularly
Try a factory reset of the home hub.
If that does not fix it, then the home hub if faulty, as it should not keep doing a kernel restart.
There were issues with failing power supply units.
stumac
Newbie
Message 3 of 7
Thanks Keith.  I had assumed it must be a software problem since it was happening at such precisely regular intervals.  However, I bought a replacement cheap off Amazon, swapped the PSU, and now the original hub is working just fine with the replacement power supply!
Message 4 of 7
Excellent Smiley Happy
The home hub 2 power units are not very reliable, and there are many similar reports on this forum.
Many people simply ask for a replacement hub, and end up with the inferior (in my opinion) home hub 3.
Many of these "plug top" switch mode power units simply run too hot, and the internal capacitors fail, resulting in an electrically "noisy" DC feed. This causes re-boots and affects the broadband and wireless as well.
Galileo
Message 5 of 7
(Win 7)
My home hub 2.0 is doing a KERNEL Warm restart every 4-5 minutes or so but only when I enable the Local Area Connection in the Adapter settings in the Network and Security Centre.
I used to have it connected to broad band where I used to live but now just use it as a router for my home network. When I want to use the internet, I disbale the LAC and enable my wireless network.
I've read in this thread that it might be a power supply unit problem, but it seems to be fine if I don't enable the LAC.
I've hit the Restore to Default button on the side, but thats had no effect.
So could being connected to the LAC cause anything that might be responsible?
Cheers.
Log:
00:02:05   1 Jan     LOGIN User admin logged in on [HTTP] (from 192.168.1.65)
00:02:01   1 Jan     LOGIN User Basic logged in on [HTTP] (from 192.168.1.65)
00:01:58   1 Jan     LOGIN User Basic logged in on [HTTP] (from 192.168.1.65)
00:01:27   1 Jan     LOGIN User Basic logged in on [HTTP] (from 192.168.1.65)
00:01:27   1 Jan     usbmgr: USB device isn't matched the configuration
00:01:27   1 Jan     usbmgr: try /etc/usbmgr/class/module
00:01:27   1 Jan     usbmgr: try /etc/usbmgr/class/09/module
00:01:27   1 Jan     usbmgr: try /etc/usbmgr/class/09/00/module
00:01:27   1 Jan     usbmgr: try /etc/usbmgr/class/09/00/00/module
00:01:27   1 Jan     usbmgr: class:0x9 subclass:0x0 protocol:0x0
00:01:27   1 Jan     usbmgr: buffer line: remove T
00:01:23   1 Jan     LOGIN User Basic logged in on [HTTP] (from 192.168.1.65)
00:00:54   1 Jan     DHCS server up
00:00:54   1 Jan     FIREWALL event (1 of 1): deleted rules
00:00:49   1 Jan     FIREWALL level changed to Standard.
00:00:43   1 Jan     FIREWALL event (1 of 1): modified rules
00:00:43   1 Jan     FIREWALL event (1 of 1): created rules
00:00:32   1 Jan     WIRELESS interface turned on.
00:00:30   1 Jan     usbmgr: start 0.4.8
00:00:19   1 Jan     KERNEL Warm restart
00:05:18   1 Jan     KERNEL Controlled restart
00:04:44   1 Jan     SNTP Unable to contact server: 198.18.1.17
00:03:33   1 Jan     LOGIN User Basic logged in on [HTTP] (from 192.168.1.65)
00:03:12   1 Jan     LOGIN User Basic logged in on [HTTP] (from 192.168.1.65)
00:03:03   1 Jan     LOGIN User Basic logged in on [HTTP] (from 192.168.1.65)
00:02:38   1 Jan     LOGIN User Basic logged in on [HTTP] (from 192.168.1.65)
00:02:33   1 Jan     LOGIN User Basic logged in on [HTTP] (from 192.168.1.65)
00:02:18   1 Jan     LOGIN User Basic logged in on [HTTP] (from 192.168.1.65)
00:02:03   1 Jan     LOGIN User Basic logged in on [HTTP] (from 192.168.1.65)
00:01:42   1 Jan     LOGIN User admin logged in on [HTTP] (from 192.168.1.65)
00:01:28   1 Jan     usbmgr: USB device isn't matched the configuration
00:01:28   1 Jan     usbmgr: try /etc/usbmgr/class/module
00:01:28   1 Jan     usbmgr: try /etc/usbmgr/class/09/module
00:01:28   1 Jan     usbmgr: try /etc/usbmgr/class/09/00/module
00:01:28   1 Jan     usbmgr: try /etc/usbmgr/class/09/00/00/module
00:01:28   1 Jan     usbmgr: class:0x9 subclass:0x0 protocol:0x0
00:01:28   1 Jan     usbmgr: buffer line: remove T
00:01:22   1 Jan     LOGIN User Basic logged in on [HTTP] (from 192.168.1.65)
00:01:19   1 Jan     LOGIN User Basic logged in on [HTTP] (from 192.168.1.65)
00:00:50   1 Jan     DHCS server up
00:00:50   1 Jan     FIREWALL event (1 of 1): deleted rules
00:00:45   1 Jan     FIREWALL level changed to Standard.
00:00:39   1 Jan     FIREWALL event (1 of 1): modified rules
00:00:39   1 Jan     FIREWALL event (1 of 1): created rules
00:00:28   1 Jan     WIRELESS interface turned on.
00:00:26   1 Jan     usbmgr: start 0.4.8
00:11:22   1 Jan     KERNEL Controlled restart
00:11:17   1 Jan     FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 192.168.1.253 Dst ip: 169.254.245.159 Type: Echo Reply Code: 0
00:08:30   1 Jan     SNTP Unable to contact server: 198.18.1.15
00:05:08   1 Jan     LOGIN User Basic logged in on [HTTP] (from 192.168.1.65)
00:04:43   1 Jan     SNTP Unable to contact server: 198.18.1.15
00:04:38   1 Jan     LOGIN User Basic logged in on [HTTP] (from 192.168.1.65)
00:04:10   1 Jan     LOGIN User Basic logged in on [HTTP] (from 192.168.1.65)
00:03:43   1 Jan     LOGIN User Basic logged in on [HTTP] (from 192.168.1.65)
00:03:11   1 Jan     LOGIN User Basic logged in on [HTTP] (from 192.168.1.65)
00:03:07   1 Jan     LOGIN User Basic logged in on [HTTP] (from 192.168.1.65)
00:03:06   1 Jan     LOGIN User Basic logged in on [HTTP] (from 192.168.1.65)
00:03:04   1 Jan     LOGIN User Basic logged in on [HTTP] (from 192.168.1.65)
00:03:01   1 Jan     LOGIN User admin logged in on [HTTP] (from 192.168.1.65)
00:02:31   1 Jan     LOGIN User Basic logged in on [HTTP] (from 192.168.1.65)
00:02:30   1 Jan     LOGIN User Basic logged in on [HTTP] (from 192.168.1.65)
00:02:29   1 Jan     LOGIN User Basic logged in on [HTTP] (from 192.168.1.65)
00:01:22   1 Jan     usbmgr: USB device isn't matched the configuration
00:01:22   1 Jan     usbmgr: try /etc/usbmgr/class/module
00:01:22   1 Jan     usbmgr: try /etc/usbmgr/class/09/module
00:01:22   1 Jan     usbmgr: try /etc/usbmgr/class/09/00/module
00:01:22   1 Jan     usbmgr: try /etc/usbmgr/class/09/00/00/module
00:01:22   1 Jan     usbmgr: class:0x9 subclass:0x0 protocol:0x0
00:01:22   1 Jan     usbmgr: buffer line: remove T
00:01:09   1 Jan     LOGIN wireless station [D0:C1:B1:51:8B:55] can't get authorized.
00:00:51   1 Jan     DHCS server up
00:00:51   1 Jan     FIREWALL event (1 of 1): deleted rules
00:00:46   1 Jan     FIREWALL level changed to Standard.
Galileo
Message 6 of 7
Can anyone help?
Message 7 of 7
Which home hub are you using for the actual Internet connection?
