k3nny
Message 1 of 7
Home Hub 3, 802.11b/g/n Not Working Well With Streaming Media
Hi, the iPhone 4S keeps disconnecting from the HH3 when normal web browsing or streaming media on an iPhone 4S, using apps YouTube and Twitch.TV. Other symptoms is the WiFi icon flashing off and on very quickly.
This happens on 802.11n and I changed to 802.11b/g which seems to solve this. Now that Home Hub 5 is out, it looks like we are 2 versions behind?
Software version 4.7.5.1.83.8.94.1.11 (Type A)
Last Update: 18/07/13
Operating System: Ubuntu.
6 REPLIES 6
Checked2013
Expert
Message 2 of 7
Re: Home Hub 3, 802.11b/g/n Not Working Well With Streaming Media
Have you tried using a different wireless channel?
k3nny
Message 3 of 7
Hi, I tried it on auto, 12 and then 5.
Message 4 of 7
try downloading inssider and run the program and use that to locate a clear wireless channel also video streaming over wireless is never the best method
Message 5 of 7
By using channel 5 you are overlapping with two other channels that are used by wireless routers so you could be actually making things worse. Channel 12 is better but still overlaps with 1 channel. You should look for the least congested channel on either 1,6 or 11 which are the only channels that do not overlap with other routers.
k3nny
Message 6 of 7
Hi, I used Kismet, this is the list of channels highlighted in red. Channel hopping is enabled, I think it shows more information then it needs to?
k3nny
Message 7 of 7
So, what wireless channel should I use?
