JohnyCarr
Message 1 of 5
Home Hub 3
Im unable to log into my Home Hub 3!!!
It takes ages to connect to the admin site and when is does i get the screen below:
I have to reboot the hub inorder for my to log in!!! anyone have any ideas????
Johny
Tags (1)
4 REPLIES 4
Message 2 of 5
Re: Home Hub 3
try a factory reset that should cure the problem
JohnyCarr
Message 3 of 5
Re: Home Hub 3
Have tried a factory reset - Didn't help at all !!!!  😞
Anyone got any other ideas?
Message 4 of 5
Re: Home Hub 3
Get a new router.
Message 5 of 5
Re: Home Hub 3
surprised that factory reset using the recessed button on back does not clear your problem  you don't even have to be connected to the internet to enter hub manager.  are you using ethernet cable?  have you tried a different port
if that does not give you access to hub manager then repaort a faulty hub and if in contract get a replacement free
08001114567
i
