dangerous97
Message 1 of 3
Home Hub 4 compatibility with Bonjour and air print for mac
Is the hh4 compatible with Apple Air Print / Bonjour, looking to upgrade to this but I need the hub to definitely be compatible with Bonjour, (mDNS, Multicast or IGMP whatever you want to call it) so I can scan and print wirelessly to my mac?
2 REPLIES 2
Message 2 of 3
Re: Home Hub 4 compatibility with Bonjour and air print for mac
yes it is compatible you should have no problems
db218
Message 3 of 3
Yes I have that working, only ever have to check the printer is powered on occasionally.
