joeyboygolf
Message 1 of 9
Home Hub 5 No response when trying to access home page
I get no response when trying to access the home page of my Home Hub with 192.168.1.254
Message 2 of 9
Re: Home Hub 5 No response when trying to access home page
Welcome to this user forum.
Try a factory reset of the home hub.
http://bt.custhelp.com/app/answers/detail/a_id/11386/%7E/how-do-i-reset-my-bt-hub-to-its-factory-set...
Then try again using a direct Ethernet connection.
Once you can access the home hub.
Turn Smart Setup off.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/switching-smart-setup-on-and-off-on-the-bt-ho...
Communityhelp (Private website) Lots of additional information and help.
You will need to be connected to your home BT Broadband connection to view it, or any links to it that I post on this forum.
joeyboygolf
Message 3 of 9
Will a factory reset also change my wireless password back to the original?
Message 4 of 9
VeteranISPUser
Message 5 of 9
Hi @joeyboygolf. What browser are you using? A recent windows update of Edge has caused some people to find that all local is addresses are blocked.
joeyboygolf
Message 6 of 9
I am using Edge so I will try Firefox when I get back this afternoon, thanks for your reply.
joeyboygolf
Message 7 of 9
Then, if that fails,I will try a factory reset.
VeteranISPUser
Message 8 of 9
Hi @joeyboygolf
https://community.bt.com/bt/board/message?board.id=OtherBB&message.id=159145#M159145
joeyboygolf
Message 9 of 9
Brilliant, worked a treat. Thanks
