Message 1 of 2
Home Hub 5 Playing Up?
Hi
Anyone able to shed any light / point in the right direction on this?
I have had a HH5 (A) for about 18 months, working fine for me at home.  I was away for a few days recently, and returned to find that something had gone wrong with it... it had reset itself to the original SSID (I always like to modify this).  When I tried to change it back, the router seemed to work OK for a couple of minutes, but then:
- My SSID disappeared
- Light on router started flashing orange
- Light then started flashing orange
I tried a factory reset, all worked OK (with the out-of-the-box config).  Tried to change the SSID again, and the same thing as above happened.  Tried a couple more factory resets, and now I have just left it working with its original config.
I spoke with BT Customer service, who have decided there's something up with my line- kind of interesting, and there may be more drops on it than there should be, but it doesn't sound to me like it should be the cause of the issue I originally faced!
Any idea what's going on here, or suggestions for fixing the snag?
FWIW: BT Home Hub 5 (Type A) | Software version 4.7.5.1.83.8.204.1.11 | Last updated 03/09/15
BT Infinity.
TVM
Charlie
Tags (1)
1 REPLY 1
Message 2 of 2
Re: Home Hub 5 Playing Up?
Right, looks like the Chromecast Audio snag that others have reported.  Fixed now.  See thread here:
https://community.bt.com/t5/Connected-Devices-Other/Beware-Google-Chromecast-Audio-amp-Home-Hub-5/td...
